Test field windows Nokia GSM phone
Test field windows nokia gsm phone capability, is this available on the new nokia phones like Lumia? I wonder if someone in here is familiar with this to enlighten me with the subject.
Test field is a specific Nokia App which enables you to run some performance tests on your Nokia device. Once you load it from your device for the first time through pressing "##634#", it appears in the applications list as "Diagnostics". And it is also available for new models like Lumia. For an example you can perform the following tests in "Nokia Lumia 800" model.
* Bluetooth
* Camera
* Headset Detection
* Lights
* Powersource
* Speaker
* Touchphones and Vibrates.
This is just a short list. There is much more tests you can do with it.
