TF1Book is invalid after installing SSuite Accel
I received this following error message  after installing SSuite Accel. The error displayed “License information for TF1Book is invalid”. What should I do now? Have any idea to resolve this issue? I would be thankful to you.
Accel
License information for TF1Book is invalid.
Answered By points N/A #188052
Hi James V Rose,
The error you have received from an ActiveX component that did not register on installation. To solve this error simply uninstall the office suite & reinstall it, this can repair the problem. Microsoft created some corrections to their system paths & registration techniques.
If the above mentioned resolution does not work, try the following:
1. At first open the “Run dialog box” on the main Start Menu of Windows
2. Then type the command script into the “Edit box” – command “regsvr32 vcf132.ocx”
3. Next click the “OK” button.
If you are running Windows Vista or Windows 7, follow these steps:
First of all “Register” the component from an elevated command prompt. Right press on the icon for “Command Prompt” on the Start Menu >> select Run as Administrator. You can prompted by UAC to support the elevation. Once the “Command Prompt” window is open, run “regsvr32  vcf132.ocx”command from that Window &  it must succeed.
Best Regards
