The best way for transferring is Export users from active directory
How to export users from active directory to different file structure or format? How can we transfer or export files to the active directory to CSV file format files?
We extract the files from working user data to transfer it to various files here we transfer it to CSV file.
CSV- Comma Separated Values
So all the using user data will be sent to CSV file.
To do the transfer, we need to launch active directory users and the computers.
How can we do that transfer of working user data to CSV? Here are steps to be followed to perform that action of the sending.
Step 1: Open Windows Power Shell
Step 2: enter the command lines
Import-module ac
Get-ad user –filter * -properties Display names, Email address | select display names, Email address | Export –CSV c:\userswithemailaddress.csv
Note: driver or the path can be anywhere on your PC according to your wish.
Step 3: once the command line has executed then we can check the created file in the specified path what we have mentioned in the command line above.
The file is created in the directed place or the directory.
Once the folder is created all we need is the details of the persons or the active users to transfer to the CSV and the CSV file can be sent. The previous folders to various systems and can be shared easily instead of sharing the details of each and every person who are the active users.
