The best way to import is by using CSVDE import
What is meant by CSVDE? How can the user use CSVDE import and export the CSV format files? What are the advantages and Disadvantages of using CSVDE?
Comma Separated Values (CSV) with the help of CSV files we can transfer the folders directly/remotely from either doing it manually or accessing it through the active directory domain systems (DS).
CSVDE is something which we use to transfer files (.csv) using some useful command lines.
These instruction lines are used to perform any operation which was said previous. And once the command line executed the action which is mentioned to perfume in the command lines will be done.
Now let’s see how we can import and export the CSV files.
Once the domain system installed in the system, then you can find something called as Active Directory Users and computer. Now follow these steps to create CSV files and transfer them:
Step 1: go to start and click on the Active Directory Users and Computers.
Step 2: Too right we can find a column in which there will be an option named “Domain 0.4 Local.”
Step 3: right click on that button/Option you will find a button “New.”
Step 4: Click on that new button, and you will find some options. Click on the Organizational Unit.
Step 5: you will new dialogue box opened in which we can create a new file.
(The files which we are going to create now are the .csv files which can further be used to transfer)
CSVDE files are also used to send the encrypted data.
We can send the encrypted password to the trusted persons or any other confidential process.
Once the user who has encrypted the CSVDE file with a password containing many passwords or any protection sent to the other side which is the client or we can call as a receiver.
Has the encrypted file is .csv which lets us assume has the excel sheet which consists of the passwords send to the receiver.
He should also have the Software installed on his/her PC to decrypt the data or any other information which is present in the file.
And once everything is set we need to use the command lines to extract the information from it.
There is various command line typed in the command prompt/ windows power shell.
To do all of these we need to have some information in any or the other form to complete the process.
Points to remember:
CSVDE is a case sensitive.
We can export/import the files.
There are many tools available in the market to check and analyze the issues.
Any more queries just ping me or google.
