The Blue Screen Of Death: Dlkmd.sys Error
SYS file errors are typically caused by faulty hardware or corrupt device driver files, could be the printer in your case. There are various ways to fix this. Firstly, your PC device drivers and scan your computer for any malware or virus.
You can also try Uninstalling Recently-Installed Program Associated with DisplayLink Core Software v6.3.40660.0 / Dlkmd.sys
Also ,check your system files integrity with the following command from cmd (run as admin):
sfc /scannow.
Hope this helps!
Blue screen errors related to “Dlkmd.sys” can be caused by different problems with the hardware, firmware, driver, and software. Now, if you constantly see the error every time you try to print, try checking your printer software. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select your printer software among the applications and click “Uninstall”.
Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then install your printer software back. If this doesn’t work, download the driver again from the manufacturer’s website. Before downloading, select your correct operating system.
