Error messages like
“Windows failed to start.”
“The boot configuration beta for your pc is missing or contains errors.”
“\Boot\BCD failed”
“0xc000000f”
“0xc0000225”
Are occurring on the screen of my pc. How can I fix it?
There are times when after installation of a new operating system, you get a boot selection failed error message or message that says windows failed to start and due to which you cannot switch-on your computer. Mostly all the error messages are related with unable to boot selection properly or boot selection failure.
The hard disc might not have been inserted or connected properly; The Operating System hard drive might have failed to run; The OS Hard drive might not have been selected properly; inside boot device setting; The boot setting might not have configured properly.
Solving can be done by configuring the Boot Setting Properly or by inserting and connecting the Hard Disc on your computer properly again.
For configuring the Boot Setting Properly:-
Go To BIOS Setting> Advance BIOS Features> Hard Disk Drives> 1st Drive> Operating System Drive> Boot Device Priority> Operating System Drive > 2nd Boot Device> CD/DVD Drive> Save Changes and Exit> Yes And Exit.
Select Save changes option and exit; press enter key then a popup menu will appear on the screen with two option named as Yes and No, select Yes and press Enter key. This way, the problem will be solved.
