The Code “41 Error” In Desktop
A Hulu desktop error was encountered in the computer running windows by Device Manager. How to resolve this issue, and fix it as soon as possible?
The various ways of solving the above- given issue are –
The full error reads “Printer not activated, error code -41” which you can receive when using Sage 100. This can happen when you try to print to Paperless Office or with a PDF printer. There are several reasons why this happens and one is an outdated driver. If you are using Amyuni PDF Converter with Sage 100, you need to update to Amyuni PDF Converter driver 5.50 or higher.
To download the latest, go to Amyuni PDF Converter. Another cause is when you downloaded the 5.50 driver and you applied it to Sage 100 PDF Converter manually or to Sage PDF Converter, this causes the “error code -41”. Another cause is when you are using an unsupported version of Amyuni. At the moment, Sage 100 only supports Amyuni Document Converter 500.
To fix the problem, click “Start”, “Control Panel”, “Printers and Other Hardware” then “Printers and Faxes”. Next, right-click “Sage 100 PDF Converter” and select “Printer Properties”. In the “Properties” window, go to “Advanced” tab and select “Amyuni Document Converter 500”. See if this works.
