I have a laptop with Dell Inspiron 1150 battery and is recently purchased, and I am poor in using my laptop. It is showing orange lights often, and then my laptop shuts down. What could be the problem?
The Dell Inspiron 1150 Battery Is Showing Orange Light
When your laptop indicate the orange light means that it is discharging and you need to plug in your Adapter. The Dell Inspiron 1150 battery, is a powerful battery and there is no fault in the battery but avoid getting the situation like this as this would reduce the efficiency of the battery and it won’t last longer, the battery can last for 2-3 years if used properly. Don’t let your battery go below 10%.
If you are using a laptop, you should know it is running on battery and not directly powered by AC or electricity. If the power indicator on your laptop is in orange color, it probably indicates the device is low on power. In this case, just charge your laptop and it should be working fine again.
To charge the battery of your laptop, get the charger that came with it then plug it to the power. Connect the other end of the cable or connect the cable of the charger to your laptop. Locate the socket on the side of your laptop where the charger should be plugged in. Wait until the laptop is fully charged.
Consult with your laptop’s manual how to determine when the laptop is fully charged.
