The Elders Scrolls Online- Fatal Errors
Playing online games is my area of interest this time I tried something new and download a game from ESO launcher, but it was showing fatal error. Am I not able to understand it?
If you come across something like this, then maybe the following can help you-
That error seems to mean that the program you are installing is not compatible with your computer. If you want to install and play “The Elder Scrolls Online”, check that your computer meets the requirements.
The Elder Scrolls Online supports 64-bit Windows 7 and requires Intel Core i3 540 or equivalent AMD A6-3620 or faster processor, 3 GB RAM, Microsoft DirectX 11-compatible video card with 1 GB video RAM, sound card, 85 GB free space, and internet connection. If your computer is running on Windows 7 but you see this error, check again if your machine is 32-bit or 64-bit.
The game will not run on 32-bit platforms. Try also installing the game as administrator. Right-click the installer or setup file and select “Run as administrator”. The game “The Elder Scrolls Online” is an MMORPG or Massively Multiplayer Online Role-Playing Game developed by ZeniMax Online Studios, published by Bethesda Softworks.
