The Error 0x80070718not Enough Quota
Most of the time, when you encounter this issue it is when you are trying to copy a file from their PC to a network folder. This error message is seen to be coming across. It can be due to a number of reasons; It’s likely seen that in most cases, it occurs because of default Disk usage limit is not enough to accommodate the shared files. You can rectify by raising the limits if both the general and temporary space from the sync center options. The other reason being default in location, if it is set on the SSD Drive default to save location to traditional HDD.
It also arises because of the file being corrupted. You can remove them by running the Windows file and folder fix it. Press Windows key+R to Run dialogue box, type ‘control.exe’ and press Enter to open classic control panel interface. Inside, you will fond control panel, search ‘sync enter’ then press enter. Then go to ‘ Manage offline Files’ then go to “ Disk usage” click change limit button. UAC, when you see an increase in the amount of space temporary between 70%.
