The Error Code 0x000000e Indicating Warning Message
The error code 0x000000e is the warning message which states to Recover your PC. Your Pc needs to be fixed some things related to drive configuration or a hardware failure may have occurred in the system. The error may appear in the form of ‘Required device is inaccessible.’ “A required device isn’t connected or cannot be accessed,” “ the selected entry could not be located.” the boot selection failed.
All these errors may occur due to the file being corrupt, or the Windows.exe file is not accessible. You can fix this error by Rebuilding boot configuration data file when it’s done press Y to let it boot from the list. You can also run automatic repair utility. Check all your physical connection. It includes USB storage devices. CD’S DVDs etc. Check your Windows 8.1 \10. WHQL support setting. Enable it, if it’s disabled. You can rest the BIOS\UEF\ Configuration. Mark your disk as online create a Bootable Windows co Media.
Notifications
