The Error In Windows Seven Script
I have Windows seven, which shows that the ‘window script host’ error. How do I rectify this problem of mine?
The script error might have caused due to several reasons. It is mostly due to the program or a file on your computer that is corrupted. It may be that the script is not uploaded correctly. In extreme situations, it can cause viruses in your system. You can first start by checking which Window operating system you have if it is Vista, download the latest service version of it, start using the service pack, then restart your computer and check if the error has stopped. Or you can identify the script error and then go to Microsoft website and then download the hotfix. You will not need to restart the computer.
Notifications
