The Error On Our Screen Error No Such Partition Entering Rescue Mode Grub Rescue On Our System
For this you have many ways like you may reconnect your drive to the partition or rebuilt the grub boot loader of your system.
Or just open your command prompt as well type the following mentioned command
After writing these commands go to the start repair option. Let the process to be complete. After this you will again get some error messages, now close all those messages and then click on option ‘View advanced options for system recovery and support’ and then once again click on ‘Startup Repair’. Now, again your process will give some message, just finish it and then remove your repair drive and then restart your system. Our process is expected to be solved.
