The Hardlock Api Error Code 38
What does hardlock API error code indicate? What causes this error to occur? How can I solve this problem?
The hardlock API error code 38 arises as a result of some files being missing or may be corrupted from the system. At times when you try to upgrade it or your files which is not letting you upgrade it. This error code 38 can result in lock-ups, slow PC performance freezing of your system, suddenly shutdown.
Never the less you can fix this problem by downloading “smart PC fixes” when it’s done downloading ‘smart PC fixes’ then Click on fix this will fix all the grid that you face in the hard lock API error, code 38. When you see this type of error it’s better to solve it at the earliest to protect computer security and information. Smart expert fixes cleaner software. It helps you by reminding you that it’s time to fix your package. It gives you tips to keep your computer safe.
If you are referring to error code “38” which you can see in the Device Manager, this happens as a result of Windows being unable to load the correct device driver related to the program you are trying to use. This problem normally happens if the driver is corrupted or an earlier version is already installed causing a conflict with the resources assigned to the device.
The full error reads:
“Windows cannot load the device driver for this hardware because a previous instance of the device driver is still in memory. (Code 38)”
Another possible cause is the device itself or errors in the registry. To fix the problem, first thing to do is run the troubleshooter. Click “Start,” “Control Panel” then “Troubleshooting.” If you don’t see this, set view to “Small icons” located on the upper right corner of the screen. On the next screen, click “View all” on the left pane.
In “Troubleshoot computer problems” screen, select “Hardware and Devices” then follow the instructions. If this doesn’t help, try to uninstall the USB controllers. Click “Start” then right-click “Computer” and select “Properties.” On the next screen, click “Device Manager” on the left pane. In “Device Manager” window, expand “Universal Serial Bus controllers.” Right-click on the “Host Controller,” select “Uninstall” then “OK” to confirm.
Repeat this on other Host Controllers if they are not uninstalled automatically. Close the Device Manager when you are finished then restart the computer. Windows will reinstall all USB controllers automatically on startup. If the problem continues, try cleaning the registry. Download PC Tools Performance Toolkit and install. Once installed, start PC Tools then go to “Performance” tab and click “Clean Your Registry.”
Make sure “Complete Registry Scan” is selected then click “Start Scan.” Wait until the scan is complete then click to repair them.
