Can anyone enlighten me about the Internal Server 500 error without the use of jargon. (Picture is asshown below). I want the simple steps to remove this. Please, technical world, I need help.
The Internal Server 500 Error Is Totally Getting On My Nerves.
Hey there! The 500 Internal Server Error message is displayed when there is no specific suitable message for the error implying there may be many causes for this error in the server which hosts yourwebpage.
To get rid of this error, check the logs for any Apache and PHP error on your server which will provide information regarding any code failures or other potential causes. Similarly, if you are using .htaccess, check its configuration for syntax errors. To confirm .htaccess as the cause, try removing or renaming and try reloading the page. Minimizing PHP script attempts to connect to too many external connections also reduces the occurrence of the Internal Server 500 error.
