The Issue Started Today While Windows Activation Gives 0xc004e003 Error
Write about the 0xc004e003 error? what is the cause of the error code, and explain the methods to overcome this error message?
The 0xc004e003 error problem occurs if the license validity interval has expired or if the license is not signed correctly. Suppose the user enters the wrong product key for the activation of the Windows, then this also becomes the reason for the occurrence of this error. Error 0xc004e003 indicates that “the Software Licensing Service reported that license evaluation failed.” The solution to fix the error is as follows:
Solution 1:
Activate Windows over the phone.
Step 1: Hold Windows Key + R and type ‘SLUI 4’ then press Enter.
Step 2: Select the country from the drop-down menu and click on Next.
Step 3: Now, you will get some toll-free phone numbers to which the user can call to get the Confirmation ID.
Step 4: Enter the confirmation ID and click on Activate.
Solution 2:
Change the product key.
Step 1: Hold Windows Key + R and type “SLUI 3,” then hit Enter.
Step 2: Type the new product key and press Enter.
