The Issue Started Today With JavaScript, And An 800A138F Error Occurred
Briefly explain the 800A138F error? Describe the cause of the error code and explain the solutions to troubleshoot this error message.
Error Code: 800A138F JavaScript has encountered a problem and needs to close. We are sorry for the inconvenience. Error code 800A138F is also known as JavaScript Error 800A138F. Runtime Error 800A138F happens when JavaScript fails or crashes while it’s running. The solution to overcome the 800A138F error code is as follows:
Solution: Update/Reinstall Conflicting Programs.
Using Control Panel
Step 1: Click on the Start and type Control Panel, then open it.
Step 2: Click on Uninstall a Program.
Step 3: Select the problem programs and click on Update or Uninstall.
Using Other Methods
Step 1: Click on the Start menu and open Settings.
Step 2: Choose Apps and scroll down to select problematic programs.
Step 3: Choose to uninstall or click Advanced options to reset the application.
