The Issue Started Today With Opening The Application Which Gives 0xc000007b Error
Discuss on the 0xc000007b error? what is the cause of the error code and explain the methods to overcome this error message?
0xc000007b error is an application error that occurs when the user opens an application that uses the .NET framework. The error code means an invalid image format. Specifically, the user is attempting to start an application that is designed to run on a 64-bit operating system. But the computer is running on 32-bit Windows and it can’t load 64-bit dll. The steps to fix the problem are as follows:
Solution 1:
Install or repair the latest version of .NET Framework.
Step 1: Click on Start button and open Programs and Features in the Control Panel.
Step 2: Click on “Turn Windows features on or off.”
Step 3: Find and click on .NET Framework 3.5 and press OK. Then start downloading the application and install it.
Step 4: Restart the computer and check for the error.
Solution 2:
Update DLL
Step 1: Download 32-bit xinput1_3.dll and extract files with a compression tool.
Step 2: Copy the extracted file to the given location: C:\Windows\SysWOW64 and paste it there.
Step 3: Select Copy and Replace if any prompt appears.
Notifications
