The Operating System Throws The Chainloader Bootmgr Error 13
What is chainloader and bootmgr? What is chainloader bootmgr error 13? How to fix the chainloader bootmgr error 13 when there is a problem with the boot manager?
Chainloading is the method used to change the current data with the new data like it replace the currently executing program with the new program. Chainloader is the command used to set up this. The bootmgr means Boot Manager. It is the small part of the software that loaded from the volume boot record. The bootmgr helps to start the operating system, and if it is, missing then the operating system won’t load. The chainloader bootmgr error occurs when you load the operating system with any other software.
Steps to fix the chainloader bootmgr error 13:
1. For this, you have the USB containing your operating system.
2. When the error occurs, you see the red window on that red window select the windows 7 with SLIC Loader (default) then press enter.
3. Then restart your computer and goto the boot menu, then goto select boot device and select the USB and press enter.
4. This redirects you to install the windows popup window the install the windows simply clicking next.
5. After restarting the computer, you see the System Recovery option popup window there you can recover your data.
