The System Requirements For Paint Shop Pro 8 Updates And Its Features
Hello, notify the systems requirements for Paint Shop Pro 8 updates and the new features in the updates as well. Reply ASAP and thanks for looking in it.
Hey, the system requirements for Paint Shop Pro 8 updates is supported in windows 98/2000/ Xp and many others. Also it will required min of 128 MB of RAM and need 200 MB of free spaces as the HDD. Also the resolutions for the same will be 800 x 600 only. And it works on the internet explorer 5.0 or higher. Its updated features are listed below.
• The user interface is changed.
• It consists of integrated learning tools as well.
• Also has a new tool which is used to create the professional tools also.
• Also it shares the images with others as well.
• It has new filters add in it too.
Paint Shop Pro 8 is part of the Paint Shop series of digital imaging and photography products from Jasc Software. It is the most complete, easy-to-use application for creating professional digital imaging results. It helps you produce professional results by combing automatic and precision tools with a built-in learning system.
Paint Shop Pro 8 supports Windows 98 Service Pack 2, Windows 98 SE Service Pack 1, Windows NT 4 Service Pack 6a, Windows Millennium, Windows 2000, and Windows XP. It requires an Intel Pentium or equivalent processor, 128 MB RAM, 200 MB hard drive space, and 800 x 600 16-bit screen resolution. Microsoft Internet Explorer 5.0 or higher is the only supported web browser.
Paint Shop Pro 8 is an enticing new update from the previous Paint Shop Pro 7 with new features offering faster loading time and smoother handling with control.
