The Trouble With 0x80004005 Network
Hi, I am Rohan. I’m unable to connect my file server on the network. Every time I tried to connect, a message popped up showing, 0x80004005 network error.
If you are not able to connect to the connection, it can be 0x80004005 network error. Try to diagnose your connection by clicking on the same. If the error still pops up, then try to troubleshoot it by clicking on the button, “Troubleshooting couldn’t identify the problem.”
Else try the following way:
1) Click on start
2) go to the control panel, and then select features.
3)Click “Turn Windows features on or off.”
4)Then click on SMB 1.0/CIFS File Sharing Support and select it.
5)Disable SMB 1.0/CIFS Automatic Removal and SMB 1.0/CIFS Server.
