I am facing error code 39 while I was installing a device. The error is displaying that, Windows in not able to load the device, the device drivers are corrupted or missing.
The Window Is Unable To Load The Device, Either The Device Drivers Are Corrupted Or Missing (Error Code 39).
The error either could be because the device drivers are missing or corrupted. For this
a. Restart your computer.
b. In the Device Manager, select the device and open device properties. In the properties, select the Driver tab.
c. Select the Uninstall option present there.
Now, restart your computer. After the restart, go to device manager and click on the Action button and in the Action click on the Scan for changes in the hardware.
Another method is to create a backup of the registry. In the Start Menu, click Run. In the box, type Regedit and press Ok. Remove the lower and upper filters in the key. At last, restart the computer.
