The Windows 10 Update 0x80072af9 Needs To Be Upgraded
Windows 10 has made available stability and better support for all the users, even though with such benefits some problems like update error code 0x80072af9 is being faced by some. This problem indicates to upgrade the system, which will lead to security in the overall Microsoft office. While sometimes it occurs while upgrading this error. For this, you need to check your antivirus software. The interference of antivirus with the system causes this problem to arise.
You need to disable it to get your problem solved. It might also occur when you are trying to download the Windows store. Some faced this problem when using outlook. You should reinstall the Microsoft office and then try to see if it works. An antivirus plays an important role to protect the computer, but at times it does not let you do some important work. You need to download the best version of antivirus such as Bite fender which will not interfere with your system.
