Themida Error: An internal exception occurred (Address: 0x0)
Whenever I start the process to load my game which is downloaded from HellaHell's installed version download central point. The game patched is looked like ok and just fine, it becomes loaded XTrap and HGWC is looking also be fine, but when I proceed the process to the next I face an error message.
I am attaching the error message screen shot with my question so it is self-explanatory.
Please observe this error message.
Error Title: Thermida
Please, contact support@oreans.com. Thank you!
I want to tell you that I am running Windows 8 RP [64-bit operating system], and I tried the installation with or without firewall ON and OFF. Even I tried it by getting OFF my antivirus auto settings, but not succeeded.
It is requested to all of you, to help me out of this error and suggest me about the remedies, please.
Thanks in advance.
Answered By 30 points N/A #171970
 Hello Calvin S Cole,
Please make sure that your system requirements meet completely with the need of game. For instance you need to check that your CPU must be Intel Pantium 4, Ram 512 MB, Graphic card 128 MB, Sound card direct X8 and should must be HDD: 30 MB.
For check your system requirements you need to right click on the My computer then on properties and on general tab.
