I'm trying to integrate my MS Outlook 2010 messaging and collaboration client with Firefox. I have Windows Xp 64-bit, sp2 and Firefox 32-bit 18.0.1. Is there an extension firefox lync for Microsoft? Any suggestions would highly be appreciated. Thanks.
Is there an add-on or extension firefox lync for Microsoft?
Dear Theresajmickens,
There is no official integration for MS Outlook 2010 with Firefox which can help you directly in handling your messages.
But if you want a good message handling tools for your emails and already integrated with Firefox, you can try to use
An outlook Button tool which is provided on the Mozilla web site to be used in emails handling for users.
The direct download site is:
https://addons.mozilla.org/en-US/firefox/addon/outlook-button/
Hope to be very helpful for you.
Best regards,
Don Muench
Hi Theresa,Â
If you already have the MS Lync Client installed in your computer and your default browser is Firefox, the first time that you join a meeting for example will push your Firefox to install the plugin.
However in some cases Firefox won’t be able to locate the plugin.
In this Scenario all you need to do is go to this link.
Hope this helps!Â
