I am looking for an Add-In or any software that allows me to cross out a day on my calendar once the day is over.
I hope you’ll be able to give me suggestions or website links to where I could download it.
Thank you.Â
Is there any add-on that can cross out a day in calendar?
Hallo Simon Atkins,
I do not think they is a specified automated software that will do entirely want you are saying, I mean crossing out a day on your calendar once the day is over, but I will suggest that you just use a dry erase and it will help you check the appointments that are done with on the calendar manually.
But if you want to use an application, I will suggest the Datebk6, which offers you functionality close to what you want with the strikeout option, so that you can strike out any event in the calendar that you need no more.
Another application that I will suggest you try is the TMP program, which will change the background color and the font for the days that you are done with for the appointments, which I think is close enough to what you want.
__
Regards
Mahesh Babu
