Is there any alienware software updater?
Hi, everybody! I would like to ask you a question. Is there any alienware software updater? I've heard just recently that Alienware has been able to release a software update which includes improved power management features. I don't have the leisure of time to check on the internet, that's why I would like to know if there are any mailing lists which I could subscribe on in order to be updated with my software. Please share those links with me. Thanks!
Best Answer by Davidson Mudge
Answered By 0 points N/A #180400
Hi Jeviery,
Alienware update will work same as the windows update, your driver, software and even your Operating system update can be listed or queued on your windows update. You can set your windows update to install it for you automatically. However, if there are upgrades you did on the computer then you can check the updates one by one, sometimes the safest option on updating is to prompt you first since other updates can cause issues or problems on your existing computer.
Answered By 0 points N/A #180401
Hi Jeviery Ero,
Dell has been released their software update for Alienware product (M11x R2) , this update is to fix the issue about the battery in Alienware, it gives more battery life improvement and measured an extra 45 minutes more battery life. You can download the latest software update on dell site or you can subscribe to Alienware newsletter at http://www.alienware.com/newsletter_registration.aspx
