Is there any bulk Google index tool?
Hi.  Is there  any good bulk google index tool?  I'm having 5,000 profile backlinks each day putting Google to a crawl.  I need a tool that can split the list of links and one that could generate html files for them.  Any leads?
Best Answer by
Answered By 0 points N/A #143019
Hi there,
Currently, a lot of Webmasters are using a website tool to calculate indexing of their websites in bulk. You can visit the website http://www.hupso.com/www/indexcheckingtool.comand then just simply follow the easy steps to check for the indexes.
Have a nice day and I hope this will help you!
Answered By points N/A #143020
At present when you wish to check site indexing in Google, you need to go to Google & key in site “domain.com” for checking every domain. But if you have a bulk list of domains you need to add your sites to Google Webmaster Tools. Here I have listed some Google index tool.
1. http://webmastercare.com : this is a superb tool no need to login, download, and no limitation of URLs checked, only require to check in portions of 25 as well free tools.
2. https://www.marketingignite.com/ : this free index checker tool helps you to check to see the number of pages visited and connected with the Google. Its use is very used just enter your website URL and click on “Check”, the result will be shown.
3. https://www.serversfree.com/ : With this tool you can find out how many of your or participants’ websites pages are on Google search engine as well helps to observe if your site is sandboxed via Google search engine or not. It is very easy-to-use, just enter your URL and press continue.
Hope these tools will be helpful for your task.
