laurofarr
Posted on - 11/01/2011
Hi All,
Is there any DSL small filter that’s available and can be functional as the usual size filters? I tried the inline filter but it won’t fit properly on my phone. Can you please suggest where I can get the filter that I need? Any help ? Thanks
lee hung
75 points
Is there any DSL small filter ?
Hallo Laurofarr,
I guess there should be a small DSL filter, the DSL itself is already a micro filter meaning that it is so small, and you can use it for performing DSL installations. What the DSL does is filtering the line interference to the standard telephone equipment, and this happens the time when the equipment lines have been made to share the same line with that of the DSL service.
One thing that you have to note while using DSL is that data that is being transmitted will not flow at the same speed as the data being transmitted upstream.
Hope this helps.
__
Regards
Lee Hung
