Marie Amos
20 points
Posted on - 05/02/2013
Hello Programmers,
Normally I use a handy utility to convert my different xls project file to html format. Now I am searching if there is any good quality professional application which will convert xls to html code. I wish somebody with programming experience could help me. Is there anybody here?
Is there any easy way to convert xls to html code?
Tableizer is a simple tool used to convert xls into html table code. Just copy the files and paste it into Tableizer, it will generates the html code that can be used on your website.
Please you can try online file conversion sites like Zamzar.com and online-convert.com. Luckily many are free online conversion websites. You can convert xls files to html without the need to download the software and get vast information about xls and html file extensions.
Or visit tucows.com and download the latest file conversion software.
