Is there any free audit log tools for monitoring purposes?
Hi experts,
I want to change the track in the firewall for the compliance purposes. I couldn't purchase SIEM solution. That's why, I need a tool that is able to collect audit logs in SYSLOG from the firewall. Is there any free audit log tools for monitoring purposes. Please help me.
Best Answer by Drake Vivian
Answered By 0 points N/A #155471
Dear user,
You can download Splunk, which is free and best for your situation. It is also easy to use. It has the best reporting and graphical features and it gives nice functionality in data mining. There are lots of other tools which are free to use. You can download Splunk from the following website:
https://www.splunk.com/
Hope this will help you.
Thank you.
Answered By 30 points N/A #155470
Hi there Halin Dan,
There are several free tools that can give you all the data you'd like to collect. As the most complete, and most important, free solution I'd suggest you to use the software name Splunk. It would be just perfect for collecting everything you need, it is very simple to use and absolutely free is you have less than 500 MB of logs per day. You can find it and download it from the official Splunk website – https://www.splunk.com/.
Splunk
Depending on the amount of data you are planning to collect you may also check Logwatch, awstats, ossec or Adiscon log analyzer.
