Emily Haist
10 points
Posted on - 04/06/2012
Is there any free domain hosting and web hosting that I may use to publish my website so that my friend will be able to see it?
Is there any free domain and web hosting?
You first need to determine the type of web page you are up with. If you are using a simple HTML webpage then any hosting server is OK. However if you are using PHP, then first know whether the server supports PHP or not. If you are using ASP.NET services, I mean .NET framework, then try asking the supported features possible with the server you are hosting to.Â
There are many free we hosting sites, where you can n host for free as a trial.
Search the web for free web hosting.
aspspider.net is free to a limited period which supports .NET platform, preferably, ASP.NET.
If you are looking for free domain hosting, try checking these free web and domain hosting services:
000webhost.com Free Web and Domain Hosting – they offer free domain and web hosting services. They support domain names like yourname.com. In case you don’t have your own registered domain, they also provide free subdomain. They support all international domains. They also offer an affiliate program where webmasters can earn money. You can earn 5$ for each visitor that gets registered to the site.
Weebly Free Domain Hosting – they provide different domain hosting alternatives for webmasters. Webmasters can publish their site on a free subdomain of weebly.com. If you already own a domain, you can import your domain from another domain provider. If you don’t have a domain, you can directly create a new domain via Weebly.
FreeHosting.com Free Website Hosting – they offer free website creation if you don’t have a website yet. There is no restriction on the file size that webmasters want to upload. They support MySQL, FTP, CGI, ROR, PHP5, CRON, Python, and File Manager.
If you are looking for free domain, you can check for MilesWeb, offering best web hosting services. You can avail a .IN or .Co.In domain name, free for one year with selected cPanel hosting plan.
