Is there any free spreadsheet program?
I want to use free spreadsheet program. Is there any free spreadsheet program that is available to download?
If yes, then where can I find one to download.Any help would be appreciated.
Hey Benjamin Morgan!
If you want free spreadsheet program I will tell you some best spreadsheet program. I am also using the same programs for the spreadsheet.
The best program is Openoffice. you can go to openoffice.org and download it from here.
This program is very easy and user friendly. You can use it without any difficulty.
Second program I would like to suggest you is, Lotus Symphony. This program is also very user friendly and easy to use.
Here I am going to explain you one more thing, if you want to excel work online then the best online site for spreadsheet is Google Docs. You can visit this website and can create your excel sites online.
Hope it will help you.
Hi Morgan,
Yes, free spreadsheet exists. You can download them and can use easily. In above comment, he said about open office. But, I am giving you a new idea. Go to https://www.libreoffice.org/ It is compatible with everything. It also has the recovery option in case of shutting down your PC. Thanks.
