Is there any freeware excel add-in??
Hi Quikee,
There is no freeware Add-in in Excel regarding enhances Excel graphics. Excel is complete software to create their graph pertaining their figures. Also, you can see Excel 2010 if your requirement is not completing in previous version. Otherwise, if you also not satisfy to Excel graphics you have to create graphic your self in any graphic design software. If you know Adobe photoshop, thus designing of graphic will be very simple for you to design as per your demand.
Just Install Adobe Photoshop, make your desire design and when finalized, save file as a JPG.
Afterward, open Excel, go to insert menu and put your design file among or amongst your data where you want show your graphic files.
Hi Quikee,
Let me try to help you. For your first question, there are many software like that for free. For graphs, you can use yEd Graph Editor. This software can be used to make a powerful diagram and can be used to generate high-quality diagrams. You can download this software from this URL : Download yEd – Graph Editor
For next question, the answer is same, there are many. There are many freeware excel add-in’s. Here, I make a list of free add-in. AbleBits – Download Freeware Add-ins for Excel
Boost Add In
BOOST is an all-in-one suite of time-saving keyboard shortcuts, formatting, and auditing tools designed specifically for people who build financial models in Excel®. Boost Add-In for Excel
Microsoft Analytics for Twitter: Download BoostPro
Do you use Twitter? This is an add-in made for Twitter. It is used to crawl Twitter data dan have the results displayed inside of Excel. Cool, isn’t it? You can download from Microsoft or maybe you want to know more. Let you check this url.
Do you remember something? Yes, ASAP is for As Soon As Possible. This add-in is called this way because it significantly reduces time-consuming work. Using this add-in, you can have your work done faster. So, to download this add-in, go to this url. ASAP Utilities for Excel
