Is there any freeware viewer Garmin img ?
Hi Friends, Is there any freeware viewer Garmin img, that will enable me to view the Garmin img Map. Thanks
Hey Deborah ,
I tried to find on the net a freeware viewer Garmin img that you will be able to view garmin img map and find this free application " GPSMapEdit " Try to download from the official website by this link : http://www.geopainting.com/
And now enjoy your self by this cool application
Yes here is a free program for you called as
GPSMapEditÂ
it will open all the Garmin images but it will not open those files if they for NT maps ,you will have to use another program known as
gmaptool
it is used to break up large files into smaller ones then GPAMapEdit  will work easily.
