Is there any Joomla Mp3 Player available ?
Hi
I want to know that is there any joomla mp3 player java is available? What are the features and compatibility of this Joomla Mp3 Player ?
Hi
Hi Alisonnlopez,
Joomla is another great cms for maintaining websites. You were talking about joomla
mp3 player. I think you need Simple MP3 Player extension for joomla, which is
very easy to set up and use.
I have just checked in official site of joomla.
https://extensions.joomla.org/extensions/extension/multimedia/multimedia-players/simple-mp3-player/
Hope you have gotten your solution ready.
Best of luck
Thanks
Mothy Stewartyi
Hello Alison,
There is an extension for the joomla mp3 player that you can use. It is very easy to get it and it gives you all the benefits of one normal MP3 player. The player have various styling options, improved administration, more background images and much more. I think that this extension is the best solution for you.
Hi There,
You can use some Joomla extensions which you will easily find in the Joomla extension directory. One of the powerful extensions is allvideo plugin. It is truly the all-in-one media management program solution for Joomla and a must-have classic extension for any website based on Joomla. You can use this plugin to embed media which will be hosted easily on popular video sites like YouTube, Vimeo, Dailymotion, SoundCloud and so on inside your Joomla articles.
