Is there any Mac beats per minute converter?
Hello everyone,
I need to convert BPM (beats per minute) meta data in mp3 files. What is the suitable technique for this operation? Is there any mac beats per minute converter? I want to operate indexing after a certain number of digits, going end of an mp3 after a certain length of digits, insert decimal point etc. I need your help.
Best Answer by Ian M Tyner
Answered By 10 points N/A #157849
Hey Austin, Hello there.
There is this software called BPMer which I recommend you to look into, you can use it for trial and if satisfies your need you can always buy.
It is easy to use and works for most of the tracks you can download the software from the official website or iTunes.
Regards Ian M Tyner
Answered By 0 points N/A #157850
I found another version that is free for download BPM analyzer1.0.1; this will let you convert the beats per minute in a short period of time. Not only conversion, you can also mix and cut songs on this application.
You can also apply certain digit for the music you are composing. Lastly, this is also user friendly.
