Kyle Berry
30 points
Posted on - 02/22/2013
I have downloaded android Amiga UAE4Droid and Droid EmuRom but they are not working. They are asking a kickstart file. Why I am seeing this? Is there any fault on my android Amiga download? Please help me.
Is there any method for android Amiga download to apply?
Hi Kyle,
Did you download UAE4Droid from android market? If yes then there should not be a problem. If not I will recommend you to get it from android market and reinstall it.
After it start UAE4Droid and configure to set ROM you can browse the location of your kickstart ROM file.
It is in .rtf format after that you can set the location of .adf files.
Hope this will help you.
Thanks,
Edward.
Hello Kyle Berry,
Android is the most famous and popular platform for smartphones. There are a lot of applications for the Android platform. First, check that there are no problems installing your Android Amiga UAE4Droid and Droid EmuRom. If no problems occur, you must uninstall it, then restart your phone and install it again. Now, is your application okay? If not, the application may be the problem, so you must download it again from the
Google Playstore and install it.
This may help you to solve the problem.
