Is There Any Method To Convert PPT 2007 To Video?
Hello guys,
I have created a Powerpoint Presentation using MS Powerpoint 2007. I want to save it as a Video. I have tried, but it didn’t work. How can I Convert PPT 2007 to Video?
Hello guys,
You cannot convert PPT to a Video using MS Powerpoint. But, if you have Movie Maker in your Computer then, you can create a video from the Slides of your PPT.
1) Open the PPT in MS Powerpoint.
2) Click on the Office Icon in the top-left side of the window.
3) Click on the “Save As” option, and you will see that a Dialog Box will appear.
4) From the “Save As Type” drop-down menu, select “JPEG” Format.
5) Click on “Every Slide” when it asks whether you want to save the Current Slide or Every Slide.
6) After that, Open Windows Movie Maker.
7) Click on Import files, and select all the Pictures of the Slides, and Import them.
8) Apply the Transitions and effects that you want.
9) When you make all the changes, click on “Save As” button. That’s it.
You can now, save your file as a Video.
