Is there any mobile website conversion software which will convert my site?
I've a site which I also want to make mobile compatible. Is there any really good mobile website conversion software that can convert my site for mobile phone?
Best Answer by Krizileana Nadth
Answered By 0 points N/A #163719
There aren’t many smart apps that can convert your site to mobile, buy there are some good sites that can do that for free. Onbile is a site that definitely helps you beat the hurry from a mobile version of the website you desire to convert. Onbile  boasts of supporting Smartphone’s, the likes of Androids, Iphones and Blackberries. Mobile App America is another great site that is best for anyone seeking an on page Seo optimized mobile site. Lastly, Mobstac provides a HTML -5 enabled mobile version of your website that supports a number of themes and also CMS integration.
Answered By 0 points N/A #163720
Nowadays, mobiles and PDAs are outnumbering PCs and laptops, but most of their websites don't have mobile friendly sites available, so it's not possible to view some of the sites because of their high resolution. If you want to convert your site for mobile, go to the link below.
You can use this link for this purpose:
https://www.mobilifyit.com/
Some other similar service providers are:
DudaMobileMoablyWixMobileGoogle Mobile SitesAppsbarAppMakrMobifyUbikMowser,Mofuse,Movylo.
