Hi everyone,
I am looking for an online tool to build and analyze Boolean networks. It will be best if there is any open source network builder, like in a website or so. I'd appreciate if you come up with the features as well.
Thanks!
Bauman
Is there any site which offers open source network builder tools?
Hi there, you can build boolean networks in several ways:
1. You can download a software that performs that function. You can get one in this link: http://www.psych.utah.edu/stat/Network_Builder/
2. You can also do it online (as you preferred). http://www.wolframalpha.com/ will be of assistance to you. I hope this information answers your questions.
Regards
Samuel
Yes, there are a number of open source network builders which can help you perform the task you want to accomplish. Some of the open source network builders include the following:
Textpattern
Dotclear
Wordpress.com
plone
Drupal
Each network builder has its own advantage and disadvantage and can be found as a freeware or a trial version for those which are not available in free source. You can find review about the site builders in
https://www.smallbusinesscomputing.com/slideshows/5-best-and-easy-open-source-website-builders.html
Thank you.
