How can I edit a PDF file. I need this urgently because I have to create a slide. Is there any software to create and edit PDF files?
Please respond as soon as possible as I have to create a presentation slides.
Thanks in advance.
Hey Benjamin Morgan!
Do not worry about the editing of PDF document. I will tell you the simple solution of the editing of PDF document. For this purpose you have to download Openoffice. You can go to openoffice.org to download the program. Once the downloading is complete, install the openoffice in your computer.
After the installation follow these steps.
1. Open your PDF document in openoffice.
2. Now you can easily edit the PDF document.
3. Once you have edited the file, you can save it or export it as PDF or in any other format you want.
Hope it will help you in preparing your presentation.
Hi Benjamin,
You can try using PDF editor such as Acrobat X Pro.
This software will allow you to edit, delete, add, reorder text and images on your PDF. Using this software, you can turn your PDF to an editable word document. For further information, read here.
Since you mentioned that you needed this to create a slide, you can use PresentationPro. But this software is not for free. Read here.
Best Regards,
Fischarinta Cra
Thank you techyv for having people who are helpful and insightful! I now know how to edit PDFs and my work is now done in a breeze.
