Hey guys I need some good software for decoding dvd in my ubuntu pc. I have searched several pages but I can't rely o anyone. Will you please mention softwares for decoding dvd that I can use in my ubuntu?
Is there is any software for decoding dvd for ubuntu?
Your requirement for some decoding dvd for your ubuntu is available. You need not to be worry. I think you should search the pages to get the right answer. For decoding dvd you need to visit the sites http://www.medibuntu.org/ and http://www.dailygyan.com/2008/11/10-…mediately.html. Here you will get your required tools for decoding. You can also get any help regarding any issue of decoding software and also after installing it or may be the compatibility issue with it. Download your required software for decoding from the respective site and make it compatible with the existing burning software. I think it will help you.  Â
I hope you understand it.
