Is there any software to easy recovery pst files
I am unable to load pst file to my outlook as it is showing as corrupted, is there any software to easy recovery pst files
A lot of number of soft wares can do it. I tell you about few things that can recover easily.
Disk doctor outlook mail recovery is one of those kinds of software. It can recover corruption of files when using over the network, corruption inside the pst file header, corruption due to reach maximum file size and etc.
The inbox repair tool can also diagnose and repair in file. It is located at c:program files Microsoft office office12 scanpst.exe. You can use this to repair errors.
First thing is exit outlook and write the file name what you want to repair or browse files.
Then choose the option that you want to do. Â
You can check for this solution on here only at TechNet .
It helped in recover corrupted PST files into saved 4 different formats like MSG, EML, PDF and VCF and that also without need of MS Outlook configuration on system.
Good luck!!
Hello Susan Coleman,
There are several software are available that can recover pst file from outlook within short time.
But I suggest you to use PstScanner.
It is really a good one for recovery of pst files.it can recovery pst files, MS Outlook emails, calendar items, etc.
The size of this software only 17.9MB. The download link given
Thanks and Regards
Louis
