Is there any software to mix songs and photos?
Hi All,
Is there any software to mix songs and photos? I need to download program photo and songs mixing free version. Where can I find it? And what are its system requirements?
Hi All,
If you are looking for an easy-to-use video and icon editor, Pinnacle VideoSpin is certainly an honest alternative.
Don't be mistaken: this can be no replacement for giant shots like Adobe Premier or Sony Vegas. But Pinnacle VideoSpin works did well for the typical user who needs to form a straightforward video presentation as well as background music, sound effects, photos and video clips.
The program options support for the foremost widespread file formats, and a nicely designed interface that divides the operating space into 3 main sections: the list of material you'll boost your presentation, a preview window and a timeline – in conjunction with a rather annoying banner.
The timeline could be a handy tool that permits you to arrange each component in your video in terms of the position they occupy within the presentation, the quantity of your time they take and therefore the transition effects between them, among different settings.
Pinnacle VideoSpin conjointly options a special tool to form and edit title screens, beside some ready-made material like sample titles and audio effects. But I still lost a lot of advanced practicality, like adding attenuation to sound or replaces the video's original audio recording – despite reading the assistance section from finish to finish, I did not manage to form it works.
Once your presentation is prepared, Pinnacle VideoSpin permits you to avoid wasting it into a spread of formats and support, as well as AVI, DivX, iPod compatible video or MPEG.
Hi Jeannej,
Windows movie maker allows you to create a timeline of photos while a song is playing in the background. It’s completely free but there are no new updated versions of it. Windows movie maker is fairly easy to use and the setup needs minimal system requirements of around 1 GHz processors and 512 MB RAM.
Notifications
