Is there any software for outlook recovery?
Hello everyone,
I have used outlook for a project. I deleted some of the files on outlook by mistake. How can I recover it? Is there any software for outlook recovery? Please answer me in reply.
Hello everyone,
There are numerous software for the solution of your recovery problem in outlook express. You can easily search in the search engines like google, bing, yahoo etc. for this kind of software. Power Email Recovery is a popular software for outlook recovery. Outlook Express Repair Tool is another popular tool for this problem. You can download these software without paying any charge from different websites.
Hi there
You can recover those by using any kind of recovery software which you can find all over the web. In every Recovery software there is a separate option called hard recovery using this option you will be able to recover those. I recommend you do use “Fast copy Unstoppable Copier” which is the most suitable recovery software for anything.
Note – Not all the software works properly
Taylor B Campus
Thank you
To recover deleted items in Outlook, you will need a MS Exchange Server 2000, MS Exchange Server 2003 or MS Exchange Server 2007 account. If you are using MS Outlook 2007, it has a way to recover the items that you deleted permanently even if you already emptied the Deleted Items folder. To view and to recover the deleted files, follow the steps below:
1. Open the folder where you deleted the files, or locate in the Deleted Items folder and then click the Recover Deleted Items under the Tools.
2. Select and click the file/item and then click the Recover Selected Items option. You will not be able to recover any item that does not appear in the Recover Deleted Items box. If this is the case, utilize an Exchange account to make the command visible. If you still do not see the command, please contact the Exchange Admin.
