Is there any thunderbolt add in upgrade card
I am looking for something via which I can upgrade my current motherboard with the new thunderbolt tech.
So are there any thunderbolt upgrade cards available?
Grace W Runyon
I wish you had mentioned the series of your motherboard.
However, ASUS is currently offering Thunderbolt EXUpgrade card for some its 7 series motherboard.
The supported models have a unique system link connector to cable to the upgrade card which uses PCIex4 slot and a display port to serve up the “bolt”.
The detailed diagrams are mentioned below in fig T, and the support list is provided in fig s.
Fig T
Fig S
Please note these cards will be released in July, and the expected cost is about US$ 200/
You can further explore the specs on the following URL.
PT
