Is there any tool for Quota Tool GUI ?
Do anyone know about GUI that will allow you to do disk Quota setup and monitoring.
Is there any tool for Quota Tool GUI.
You should know about disk quotas. It limits hard disk space per user and per file system. You should only use disk quotas, if and only if the quota support is enabled in the kernel, otherwise it will not work.
In Unix and Linux, disk quotas already enabled.
Dear I am giving you a software Disk quota manager 5.4, you can download it from freedownloadmanager, that will monitor the GUI properties.
Hello Bryan,
I have got the point of your problem. I am giving a significant solution.
You can set the disk quotas manually .Server08 give this utility feature.
You should enable disk quota by right clicking on the drive letter. Then click on Quota tab.
Then you must edit the etc /fstab file.
Then add the usrquota options to the file system.
I hope this will help you to implement the disk quota in the graphical user interface.
Here is link of tutorial how to set up disk quotas for managing disk usage with quotas.
With this tutorial you can restrict the amount of disk space who is used by each user or group, on each partition.
And in this link you have tutorial how to use web GUI for monitoring the server system:
I hope this will help!
Williamson Mellisa
