Is there any Track Pad Phone in the market?
Hi Jennifer,
All the iPhones and iPod touch have mouse trackers and infact all of them can be used as keyboards for your computer. They have wireless mouse, keyboard and track pad, so making them a plus if your keyboard or mouse fails. Because you can easily fix the iPhone and operate with it as normal as a keyboard would do.
All you will need to do to use them is to download a desktop application companion that will enable communication between your iPhone or iPod and your desktop. So you need not worry any more because your iPhone will have all that you are looking for.
I hope this has been of help to you and will guide your judgment.
I’m not sure if you still need to use a mouse or something on the Smartphone if you indeed buy one. Like for example, in iPhone, this Smartphone uses biometric technology for its touchscreen that senses electrical contact with the skin instead of pressure on the surface of the screen.
Since its screen is already that sensitive, you can just simply slide your finger over the surface of the screen to browse the next photo or to transfer to a different menu. It’s much faster to navigate with the screen than using a mouse. You just need to calibrate the screen once in a while or maybe restore the phone to its default if you happen to notice some inconsistencies with the touchscreen capability.
