blackbeard
Posted on - 01/06/2012
Is there any way I can find out the signal strength I will get for a particular internet and telecommunications service? I was given a reference for comparison but I still want to make sure that I will get good value for my purchase by having good signal for the services that I subscribe to.
Howdy Blackbeard,
I understand that you want to make sure about the quality of the internet or telecommunication provider before you are going to buy and use them. You can find out the signal strength by looking at the signal of your phone using the telecommunication or internet service provider that you want. If your phone has a high quality signal, it means that the signal of internet provider is also fast. By doing this solution, you can compare any of the internet provider that you are targeting to use. But you are using wi-fi wireless signal, you can easily recognize the signal.
I hope this might help. Have a great day and good luck.
Zorian
